[GRASS-user] GRASS & earth curvature correction (viewsheds, LOS)
    Benjamin Ducke
    benjamin.ducke at oxfordarch.co.uk
    Thu May 26 06:26:05 EDT 2011
> Hm-hm. Citing from the website:
> "The problem is that the ratio of change due to air to curvature is
> not 1:7 (0.13), as the standard refraction coefficient suggests. It is
> 0.325.
As far as I can tell, this is a mis-understanding. The value "0.325"
applies to radio waves. Visible light is very close to 1:7.
You can read up on the arguments here:
http://forums.esri.com/Thread.asp?c=3&f=40&t=161962#474778
There is also some more information in that forum thread
regarding more realistic modelling of refraction under
different atmospheric conditions.
I realize the whole discourse is somewhat "clouded". But I don't
have access to most of the relevant literature for the time
being, nor do I have the necessary scientific background
-- so any fresh input will be much appreciated!
Btw.: using r.ecurv.comp, one can freely specify the
atmospheric correction factor.
> >> But given that most DEMs have an inherent vertical error that
> >> is greater than the influence of these effects,
> > can we quantify that? for example what's STRM 95% confidence
> > accuracy?
> From Farr et al. 2007:
> Summary of SRTM performance. All quantities represent 90% errors in
> meters.
> Africa Australia Eurasia Islands N. America S. America
> Absolute Geolocation Error 11.9 7.2 8.8 9 12.6 9
> Absolute Height Error 5.6 6 6.2 8 9 6.2
> Relative Height Error 9.8 4.7 8.7 6.2 7 5.5
> Long Wavelength Height Error 3.1 6 2.6 3.7 4 4.9
> [sorry for the ugly format, it's tab separated]
What I wold love to see is a method for probabilistic
viewsheds, which adds random +/- offsets (within the
vertical error range) to the elevation model cells,
runs the viewshed computations several times, each time
with new random offsets, then outputs the average visibility
of each cell after "n" runs (not sure how best to determine
"n"). That would be much more realistic than those over-
confident 0/1 viewsheds.
Such a method could even take into account roughly modelled
blocks of vegetation or other obstacles for which height
is hard to quantify precisely.
-- shouldn't be too hard to implement in a little script.
Ben
> >> I am not sure it's worth spending too much time on (it might
> >> be for very long distance visibility -- I just don't know).
> > it would be good for us to do a rough back of the envelope calc
> > to justify that before fully forgetting about it.
> > I guess for the worst case scenario we could try the views from
> > Mt. Everest and/or Olympus Mons and see what difference it makes.
> No need to go into mountains, just increase observer elevation offset,
> preferably in a moderately flat area to get really far views. Using
> correction for earth curvature only, max is a bit more than 100 km
> with 3km observation offset. 200km is impossible without leaving
> earth's atmosphere.
> Markus M
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
