[GRASS-user] Re: i.atcorr returns all NULL values
Chemin, Yann (IWMI)
Y.Chemin at cgiar.org
Thu May 26 23:23:32 EDT 2011
Hi Juan,
Can you please give the download link for your images,
Could you also check the output of i.landsat.toar for them and tell if
reflectance ranges are valid/logic.
Thank you,
Yann
From: Juan Benavides Duque [mailto:jbenavid at siu.edu]
Sent: Thursday, May 26, 2011 11:38 PM
To: Chemin, Yann (IWMI)
Cc: Markus Metz; Elena Mezzini
Subject: Re: [GRASS-user] Re: i.atcorr returns all NULL values
I tried Yann's code for the i.atcorr on some Landsat TM5 images
It worked very nice for images taken after 1995 but before that still
returns null values when running i.atcorr for bands 1 and 2
I used TM5 scenes from the same location for 1986, 1989, and 1996 and
the first two (1986 and 1989) had the same problem with the null
values...
sorry I can provide a way to fix it but I hope somebody will
juan c
On Tue, May 24, 2011 at 3:49 AM, Chemin, Yann (IWMI)
<Y.Chemin at cgiar.org> wrote:
>Each created visibility map holds only one value r.mapcalc
expression="visibility=${vis_list[$i]}" --overwrite so why not just use
this visibility value as input in the >parameter file instead of
creating a map where all cells have the same value?
Yes, this is a valid point, the script is designed to (hopefully soon)
encompass raster maps of visibility data (maybe interpolated...), so
this is a placeholder for the next steps.
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork at googlemail.com]
Sent: Tuesday, May 24, 2011 12:52 PM
Cc: grass-user at lists.osgeo.org; Elena Mezzini; Markus Neteler
On Mon, May 23, 2011 at 9:36 PM, Markus Neteler <neteler at osgeo.org>
wrote:
> Hi Yann,
> On Mon, May 23, 2011 at 5:07 AM, Chemin, Yann (IWMI)
>> p192 r030 image of July 2003 of Italy (L5TM) successfully corrected
>> for band 1 and 2.
>> The following script works well in GRASS GIS Trunk SVN.
> (better send as attachment since a series of line breaks got broken)
>> # For i.atcorr scripting
>> vis_list=(10 10 8 9.7 15 8 7 10 10 9.7 12 9.7 7 12 12 12 3 15 12 9.7
>> 6 15) vis_len=${#vis_list[*]} echo $vis_len
> ... this is not clear to me: why so many values and where do they
> originate from? Since we have only 6 channels to work with...
Moreover, how can it be possible that visibility is different for
different channels of the same scene? From the documentation it seems
that visibility is related to aerosol concentration at 550nm which can
not possibility be different for different bands of the same scene.
this visibility value as input in the parameter file instead of creating
Markus M
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110527/211bcf66/attachment.html
