[GRASS-user] Scripting Python from inside GRASS
Glynn Clements
glynn at gclements.plus.com
Sun May 29 11:47:49 EDT 2011
Tim Michelsen wrote:
> reading
> http://grass.osgeo.org/wiki/GRASS_and_Python
> I may still ask:
> * is there a IPython-enhanced Python scripting console withing GRASS?
No.
> * What is the preferrred way to script grass from Python?
Similar to shell scripts, but there's a Python module (grass.script)
which provides convenient interfaces to the most common commands.
See any of the scripts in 7.0 for reference.
> * Do I need to be inside GRASS shell to script in order to have all
> environment parameters set?
Either that, or you need to set up the environment manually.
