[GRASS-user] making fcell raster maps using climate data
Pawel Netzel
pawel.netzel at uni.wroc.pl
Sun May 29 23:02:48 EDT 2011
You can convert the xls file to csv file. Next, add annotation to see it as a vector (points) layer in gdal/ogr (http://www.gdal.org/ogr/drv_csv.html).
After importing the data to grass you can interpolate the data to obtain precipitation field. You can use built-in interpolation methods (for flat and homogeneous terrain) or you can use regression based on terrain characteristics (for annual and seasonal sums it works very well). Yet another option is use geostatistical methods.
Pawel
----- "Bulent Arikan" <bulent.arikan at gmail.com> napisał:
> Dear List,
> I have an Excel file that contains precipitation data in 13 columns
> (mean values for each month and annual average) from a region between
> certain years (in rows): eventually showing temporal changes in
> precipitation values. The data are taken at a weather station whose
> coordinates are known. I want to use this file in order to make an
> fcell raster map in GRASS. After some research I found few leads and
> mostly on interpolation of data. However, I am confused about the
> actual process turning the data in Excel into a raster map. I will
> greatly appreciate any suggestions as to which module to use and how
> to arrange the data.
> Thank you,
> BÜLENT
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
