[GRASS-user] GIPE modules in GRASS 6.5 and 7.0
Laura Poggio
laura.poggio at gmail.com
Thu Nov 3 05:48:10 EDT 2011
Thank you very much for all suggestions. I now managed to get a working
version of all GIPE modules in grass65 downloading older version from the
svn. By working I mean that they can be loaded and seem to work with test
data I tried. I will test them more seriously. I will also try to test them
on the 6.4.1 version.
In this way I can wait a little bit longer before starting to use GRASS 7.0
for serious work.
Thank you again.
Laura
On 3 November 2011 03:55, Hamish <hamish_b at yahoo.com> wrote:
> Yann Chemin wrote:
> > There should be a way to do that by
> > "going back in time" the SVN revisions versions.
> please restrict grass7 development in addons to the grass7/ dir!
> feel free to use the grass6/ dir for archival purposes (svn copy
> the appropriate revision); my unimplemented plan is to move the
> base raster/ imagery/ vector/ dirs into grass6/, then symlink
> them back into the main addons dir. Before doing that I need to
> study up on how well svn deals with symlinks when used from MS
> Windows. The sooner we do this, the better.
> a reminder: while we think it works pretty well, grass7 is still
> pre-alpha. Do not use it for real work, only if you want to help
> program and debug. For production use there is the stable 6.4.x
> line. Although I personally use the development version day-to-
> day as I'm trying things out and building things, with the benefit
> of hindsight sticking with the stable releases for "real"/final
> work runs has really saved my neck in the past, and it can save
> yours too.
> thanks,
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111103/c3967a96/attachment.html
