[GRASS-user] WIND file not changing, set to DEFAULT_WIND
Duffy, Garret garret.duffy at nuigalway.ie
Fri Nov 4 08:17:07 EDT 2011
Sorry, I see now...
'Set computational region to match display'
RTFM
-----Original Message-----
Sent: 4-Nov-11 12:13 PM
To: 'Glynn Clements'
Cc: grass-user at lists.osgeo.org
Subject: RE: [GRASS-user] WIND file not changing, set to DEFAULT_WIND
env | grep WIND returns no WIND_OVERRIDE variable.
I am using the "Map Display" window used by GIS Manager and not  a
monitor produced by d.mon, is this anything to do with the issue?
Is there a command to update current region to the view displayed by the
"Map Display" window?
Thanks,
Garret
From: Glynn Clements [mailto:glynn at gclements.plus.com]
Sent: 4-Nov-11 8:40 AM
To: Duffy, Garret
Subject: Re: [GRASS-user] WIND file not changing, set to DEFAULT_WIND
Duffy, Garret wrote:
> I'm having issues with my WIND file, it seems to be set to the
> DEFAULT_WIND value and is not updating with my current region.
Check whether the environment variable WIND_OVERRIDE is set. If it is,
the named region specified by that variable is used instead of the WIND
file.
> I'm thinking I could delete the WIND file and restart GRASS but don't
> want to mess anything up if I do this.
GRASS requires a mapset directory to contain a WIND file in order for it
to be recognised as a mapset. However, if the WIND file has been
deleted, you can create a new one by copying the DEFAULT_WIND file, so
it isn't a difficult situation to recover from.
