[GRASS-user] Running a Python script in GRASS6.4.1-RC2
Sat Nov 5 07:32:38 EDT 2011
António Rocha wrote:
> I have built a python script and it runs just fine in Windows GRASS.
> when I try to compile it in Linux it places the script file in script
> folder but when I try to run It I get the following error in Command
> Outputwindow:
> ExpatError
> no element found: line 1, column 0
> and it does not launch the modules Interface
> Any idea of what is happening and how to fix this?
First, try running the script from the command line with the "help" or
"--interface-description" flags.
