[GRASS-user] Re: r.in.gdal oddity
Hamish
hamish_b at yahoo.com
Sat Nov 5 22:27:37 EDT 2011
Hamish wrote:
> > WRT the -l flag, if you use 'r.in.gdal -l' you _must_
> > use r.region after to correct the map bounds+resolution.
> Maybe I am silly. But use r.region how?
n= s= e= w=
> - with -l, r.in.gdal will import ALL pixels, right?
yes, the actual array data is imported untouched,
just the
north:
south:
east:
west:
in $MAPSET/cellhd/ are changed.
r.in.gdal man page:
"While the resulting bounds and resolution will
likely be wrong for your map the map's data
will be unaltered and safe. After resetting to
known bounds with r.region you should double check
them with r.info, paying special attention to
the map resolution."
> - then I have them in (even one pixel line/row
> too much perhaps than possible by definition)
which dataset are you looking at?
for the global population count one,
gl_gpwfe_pcount_10_ascii_one.zip
the cellsize setting in the original dataset was
simply wrong. fix the resolution in the header and
it imports ok.
for the WorldClim precipitation one,
prec_10m_bil.zip
it is not so clear who's responsible for the problem,
but the thin slice happens because:
$ cat prec2.hdr
BYTEORDER I
LAYOUT BIL
NROWS 900
NCOLS 2160
NBANDS 1
NBITS 16
BANDROWBYTES 4320
TOTALROWBYTES 4320
BANDGAPBYTES 0
NODATA -9999
ULXMAP -179.9166666666667
ULYMAP 89.91666666666667
XDIM 0.166666666666667
YDIM 0.166666666666667
DatabaseName WorldClim
Version 1.4
Release 3
Created 20060101
Projection GEOGRAPHIC
Datum WGS84
MinX -180
MaxX 180
MinY -60
MaxY 90
MinValue 0
MaxValue 736
Variable Precipitation
month February
Units mm
so:
MinX != ULXMAP (?!?)
and:
west: -179.9166666666667 = +180.083333333333
east: west + NCOLS*XDIM = w+2160*0.166666666666667
= 180.083333333334
thus due to cumulative rounding error and the way
$east is calculated it sees east>west, and all
columns fitting within that sliver. but that makes
each column coord unresolvable due to the limits of
FP precision and the map unusable until you set
E<=W instead of E>W.
the culprit here seems to be the weird ULXMAP value.
so our question is if that $west value is legitimate or foul?
> - then I correct that with r.region, but in which
> sense? I would need to cut this row or all gets
> messed up?
since in the .bil header we have:
NROWS 900
NCOLS 2160
it is cell-center convention. If it were grid-
confluence convention it would be n+1, 901 x 2161.
(same is true for the population map, row*col is even)
now we also observe the cells are 1/2 cell off from
nice round numbers:
-179.9166666666667 - 0.166666666666667/2 = -180
so I suspect what happened is that the original
data was based on a grid-confluence convention,
but was exported or cropped to cell-center raster
convention in a funny way before it was distributed.
GRASS65> r.in.gdal -o in=prec1.bil out=WorldClim.prec.january
WARNING: Over-riding projection check
100%
r.in.gdal complete. Raster map <WorldClim.prec.january> created.
(no -l flag needed as not exceeding 90deg latitude)
GRASS65> r.info WorldClim.prec.january
| N: 90N S: 60S Res: 0:10 |
| E: 180E W: 180E Res: 0:10 |
at 10' res dataset I see no problem,
[GRASS 6.5.svn46412 (2011), perhaps slightly old]
but if needed, using:
GRASS65> r.region WorldClim.prec.january e=w+0
should fix it. (e=w doesn't seem to pass the parser)
The data still needs to have its nulls removed,
.bil header:
MinValue 0
MaxValue 885
r.info:
minimum: 0
maximum: 55537
GRASS65> r.null WorldClim.prec.january setnull=55537
GRASS65> g.region rast=WorldClim.prec.january
GRASS65> r.colors -e WorldClim.prec.january color=bcyr
GRASS65> r.univar WorldClim.prec.january
maximum: 736
but looks ok to me..
regards,
Hamish
