[GRASS-user] Alternative to r.stats to generate % of surface
Rainer M Krug
r.m.krug at gmail.com
Tue Nov 15 08:31:53 EST 2011
On Tue, Nov 15, 2011 at 1:35 PM, Marcello Gorini <gorini at gmail.com> wrote:
> Hi Helena,
> I have come to the same problem and solved it with ugly and very specific
> shell scripts. There is most certainly a better way within GRASS and no
> doubt you can code it much better in Shell, but anyway, this may get you
> going somehow.
> Code snippet:
> MAP=$1
> g.region rast=$MAP
> max_cats=9
> file=true_percentages.txt
> rm $file
> tot=$(r.univar $MAP | grep "^n: " | awk '{print $2}')
> r.stats -cn $MAP > stats.txt
> cats=1
> while [ $cats -le $max_cats ]; do
> ncat="`head -$cats stats.txt | tail -1 | awk '{print $2}'`"
> cat="`head -$cats stats.txt | tail -1 | awk '{print $1}'`"
> perc="`echo $tot $ncat | awk '{printf("%.5f", $2 / $1 * 100);}'`"
> echo $cat $perc >> $file
> cats="$(expr $cats + 1)"
> done
> I wanted everything in text files, so I generated these stats.txt and
> true_percentages.txt. The idea of the script is to use the actual cell
> count given by r.stats -cn and divide it by the total count given by
> r.univar.
> Note that this script is very specific and only work for categories that
> are incremented by 1. In my case, they go from 1 to 9.
> How brave I am to publicize such an ugly script, huh? :) The result sums
> up to 1 at least. Just give the name of the categorical map as input.
> Hope it helps somehow.
What about the -c flag for r.stats? You will get the cell count and can
calculate the percentage yourself.
Rainer
> Marcello.
> On Tue, Nov 15, 2011 at 9:36 AM, Helena Herrera <
> helenaherrera1980 at gmail.com> wrote:
>> Greetings
>> I want to calculte % of surface in a raster map for each Integer class
>> value. The thing is that I'm, using r.stats but the sum % values is always
>> much more (104 or 102 or 105). Is there any other (more precised) method to
>> calculate this ?
>> THanks
>> Helena
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111115/2f6a6702/attachment.html
