[GRASS-user] measuring area on a 3d polygon
maning sambale emmanuel.sambale at gmail.com
Tue Nov 15 22:01:27 EST 2011
I have a series polygons located in a mountainous terrain.  I can
convert the 2d vector into 2.5d using v.drape and a DEM, however, it
only converts 2D vector point or line data and not areas.  My task is
to calculate the area in hectares of the polygon incorporating the
elevation/surface of the polygon.  I then need to subdivide the main
polygon into smaller polygons using a preferred area in hectares.
How to calculate 2.5d polygon areas in grass?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
