[GRASS-user] measuring area on a 3d polygon
Benjamin Ducke
benducke at fastmail.fm
Wed Nov 16 14:41:56 EST 2011
I think Michael's reply (see below) to my message is
actually the answer to your question ;)
Ben
On Wednesday, November 16, 2011 10:13 AM, "Michael Barton"
<michael.barton at asu.edu> wrote:
> r.surf.area
> will calculate a topographically corrected area for rasters. So if you
> convert your vector areas to raster, this will do the trick.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
> www: http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
On Wednesday, November 16, 2011 11:01 AM, "maning sambale"
<emmanuel.sambale at gmail.com> wrote:
> Hi,
> I have a series polygons located in a mountainous terrain. I can
> convert the 2d vector into 2.5d using v.drape and a DEM, however, it
> only converts 2D vector point or line data and not areas. My task is
> to calculate the area in hectares of the polygon incorporating the
> elevation/surface of the polygon. I then need to subdivide the main
> polygon into smaller polygons using a preferred area in hectares.
> How to calculate 2.5d polygon areas in grass?
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
