[GRASS-user] Problem while compile source.."gcc.exe: installation
problem, cannot exec"
Johannes Radinger
JRadinger at gmx.at
Wed Nov 16 06:36:35 EST 2011
Hello Sandip,
I got the same error as you some weeks ago when compiling.
Please read here for my solution:
http://osgeo-org.1803224.n2.nabble.com/Compiling-WINGrass-MinGW-problem-td6947616.html
You followed the wiki (how to compile on windows)? When copying all the folders into the subfolders also the libexec folders must be copied from mingw32-make and mingw-runtime although the don't exist in the osgeo4w directory by default. Thats what helped in my case.
And make sure there are no spaces in the source tree path.
Hopefully the link above will help you!
/Johannes
-------- Original-Nachricht --------
> Datum: Wed, 16 Nov 2011 16:54:16 +0530
> Von: Sandip Maity <sandip.stesalit at gmail.com>
> An: grass-user at lists.osgeo.org
> Betreff: [GRASS-user] Problem while compile source.."gcc.exe: installation problem, cannot exec"
> Dear Frnds,
> I am getting error when compiling source by usng grass65-wxpython within
> msys.
> the error massage is as follows.
> `D:\Bhoomi\bin\..\libexec\gcc\mingw32\3.4.5\cc1.exe': Exec format error
> make[1]: *** [OBJ.i686-pc-mingw32/main.o] Error 1
> please suggest anyway by which i can solve it.
> thanks and regards.
> Sandip
NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
Jetzt informieren: http://www.gmx.net/de/go/freephone
