[GRASS-user] Joining vectors by location
Daniel Lee
lee at isi-solutions.org
Mon Nov 21 12:00:58 EST 2011
2011/11/21 daniel mcinerney <daniel.o.mcinerney at gmail.com>
> According to the documentation of [1] and previous discussions [2],
> v.rast.stats2 should be a lot faster.
Awesome! Only... I've got a problem here... Sorry to be so nooby, but
here's what's going on:
GRASS 6.4.2RC1 (ETRS89_ll):~ > g.extension extension=r.univar.zonal
WARNING: GRASS_ADDON_PATH is not defined, installing to ~/.grass6/addons/
Fetching <r.univar.zonal> from GRASS-Addons SVN (be patient)...
A r.univar.zonal/stats.c
A r.univar.zonal/sort.c
A r.univar.zonal/globals.h
A r.univar.zonal/r.univar.zonal.html
A r.univar.zonal/r.univar_main.c
A r.univar.zonal/r3.univar.zonal.html
A r.univar.zonal/r3.univar_main.c
A r.univar.zonal/Makefile
U r.univar.zonal
Checked out revision 49316.
Compiling <r.univar.zonal>...
Makefile:10: /opt/grass/include/Make/Multi.make: No such file or directory
make: *** No rule to make target `/opt/grass/include/Make/Multi.make'.
Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
I can't find any Multi.make either, except for in my GRASS 7 sources. I'm
actually wanting to work in GRASS 6, but even if I try the same command in
GRASS 7, another problem happens. Although I did swap the repository for
it, that might be causing the problem (?)? Here it is:
GRASS 7.0.svn (ETRS89_ll at Niedersachsen_Test):~ > g.extension
extension=r.univar.zonal svnurl=https://svn.osgeo.org/grass/grass-addons/
Fetching 'r.univar.zonal' from GRASS-Addons SVN (be patient)...
U r.univar.zonal
Compiling 'r.univar.zonal'...
mkdir -p
/home/lee/Documents/GRASS_Data/ETRS89_ll/Niedersachsen_Test/.tmp/pc19453/6059.0/r.univar.zonal/etc/r.univar.zonal
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
gcc -g -Wall -Werror-implicit-function-declaration -fno-common -Wextra
-Wunused -I/usr/local/grass-7.0.svn/include
-I/usr/local/grass-7.0.svn/include -D_FILE_OFFSET_BITS=64
-DPACKAGE=\""grassmods"\" -I/usr/local/grass-7.0.svn/include
-I/usr/local/grass-7.0.svn/include -o
OBJ.x86_64-unknown-linux-gnu/r.univar_main.o -c r.univar_main.c
In file included from r.univar_main.c:21:0:
globals.h:22:23: fatal error: grass/G3d.h: No such file or directory
compilation terminated.
make: *** [OBJ.x86_64-unknown-linux-gnu/r.univar_main.o] Error 1
I tried hardwiring my top include folder (/usr/local/grass-7.0.svn/) where
the makefile seemed to be looking for Multi.make into the makefile, but
that didn't help either. Any ideas?
You should be able to change the BASECOLS variable in the script
> to only output the sums, which might speed things up for you.
Do you mean just taking the line in v.rast.stats2 with
BASECOLS="n min max range mean stddev variance cf_var sum"
and removing everything except for sum? Unfortunately, my knowledge of bash
scripting limits me here, I'd just try it out, but since I can't get the
extension installed yet anyway I figured I'd ask.
Thanks a lot!
Daniel
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111121/e7a6447a/attachment.html
