[GRASS-user] Joining vectors by location
daniel mcinerney
daniel.o.mcinerney at gmail.com
Mon Nov 21 10:23:29 EST 2011
Hi Daniel,
According to the documentation of [1] and previous discussions [2],
v.rast.stats2 should be a lot faster.
You should be able to change the BASECOLS variable in the script
to only output the sums, which might speed things up for you.
Hope that helps.
Regards,
Daniel.
[1] http://grass.osgeo.org/wiki/GRASS_AddOns#v.rast.stats2
[2]
http://osgeo-org.1803224.n2.nabble.com/faster-than-v-rast-stats-td6500105.html
On Mon, Nov 21, 2011 at 4:10 PM, Daniel Lee <lee at isi-solutions.org> wrote:
> Hi Daniel,
> Very cool name :)
> You should use v.rast.stats [1] as it "Calculates univariate statistics
>> from a raster map based on
>> vector polygons and uploads statistics to new attribute columns. " Should
>> be a more straight
>> forward approach.
> Thanks for the tip, but v.rast.stats gives me all univariate statistics
> and takes a really long time (hours vs. seconds). I've got so many pixels
> that I get segmentation failures and in the end I only want the sums for
> each polygon. It also makes it a pain to delete the unneeded columns from
> the vector table afterwards. Or is there a way to only have v.rast.stats
> give me the sums?
> Thanks,
> Daniel
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111121/4c0a1f63/attachment-0001.html
