[GRASS-user] Re: ERROR with v.report
Markus Neteler
neteler at osgeo.org
Mon Nov 21 16:11:12 EST 2011
On Mon, Nov 21, 2011 at 6:28 PM, G. Allegri <giohappy at gmail.com> wrote:
> I've just found that it's a known bug:
> http://trac.osgeo.org/grass/ticket/1139
Could you add " -x" to the first line of the script?
Then run again and it should output shell debugging to
better understand what's ongoing there.
Markus
> 2011/11/21 G. Allegri <giohappy at gmail.com>
>> The following command gives me an error:
>> >> v.report map=rivers option=length units=meters
>> OUTPUT:
>> Displaying column types/names for database connection of layer 1:
>> File di input specificato due volte (english: input file was set twice)
>> ERROR: There is a table connected to input vector map
>> 'fiumi_princ at PERMANENT', but there are no categories present in the key
>> column 'cat'. Consider using v.to.db to correct this.
>> The vector layer has 227 lines and 12 categories, correctly connected to
>> the db.
>> I've also tried to update a table column and it works fine:
>> >> v.to.db map=rivers option=length units=meters columns=len
>> Working with GRASS 6.4RC1 from OSGeo4W on a Winows 7 machine.
>> giovanni
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
