[GRASS-user] Re: ERROR with v.report
G. Allegri giohappy at gmail.com
Mon Nov 21 12:28:01 EST 2011
I've just found that it's a known bug:
http://trac.osgeo.org/grass/ticket/1139
2011/11/21 G. Allegri <giohappy at gmail.com>
> The following command gives me an error:
> >> v.report map=rivers option=length units=meters
> OUTPUT:
> Displaying column types/names for database connection of layer 1:
> File di input specificato due volte (english: input file was set twice)
> ERROR: There is a table connected to input vector map
> 'fiumi_princ at PERMANENT', but      there are no categories present in the
> key column 'cat'. Consider using      v.to.db to correct this.
> The vector layer has 227 lines and 12 categories, correctly connected to
> the db.
> I've also tried to update a table column and it works fine:
> >> v.to.db map=rivers option=length units=meters columns=len
> Working with GRASS 6.4RC1 from OSGeo4W on a Winows 7 machine.
> giovanni
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111121/26c09d53/attachment.html
