Martin: > long time and most of cleanup has been done MarkusN and me. no doubt. fwiw, if you check the block logs I think you will find that you are not alone in that.. (a while ago I did some 100+) why aren't we using the standard and very well tested debian package for mediawiki? thanks, Hamish
