[GRASS-user] getting error msg "g.echo.exe not found" to compile
	source code
    Sandip Maity
    sandip.stesalit at gmail.com
    Thu Nov 24 08:01:21 EST 2011
Dear Johannes,
"Unzip the folder and copy its sub folder contents into the corresponding
sub folders of c:\osgeo4w\apps\msys."=> I have to copied every sub folder
of the make file to msys directory. in many cases the sub folder name also
same. then i have to digging or overwrite.
In compile_on_windows, please see the 6th step here also i am facing same
problem for copying.
Please help me.
Thanks and regards.
Sandip
On Thu, Nov 24, 2011 at 3:03 PM, Johannes Radinger <JRadinger at gmx.at> wrote:
> Hello,
> How did you install the new make 3.81?
> as I had the same problem some weeks ago,
> here what needs to be done (at least in my case):
> 1) It is really important to follow the wiki (compile_on_windows)!
> 2) Download the latest make program compliant with the OSGeo4W framework
> from  here. (download only from here and not any installer or
> anything...)
> 3) Unzip the folder and copy its subfolder contents into the corresponding
> subfolders of c:\osgeo4w\apps\msys. This step is really important!
> 4) Close and re-open msys
> 5) make -version
> /Johannes
> -------- Original-Nachricht --------
> > Datum: Thu, 24 Nov 2011 09:01:01 +0100
> > Von: Markus Neteler <neteler at osgeo.org>
> > An: Sandip Maity <sandip.stesalit at gmail.com>
> > CC: GRASS user list <grass-user at lists.osgeo.org>
> > Betreff: Re: [GRASS-user] getting error msg "g.echo.exe not found" to
> compile source code
> > On Thu, Nov 24, 2011 at 6:43 AM, Sandip Maity <sandip.stesalit at gmail.com
> > wrote:
> > > I downloaded make 3.81.
> > > But after installation make is 3.79.1
> > > Please suggest any idea.
> > Please contact the OSGeo4W list - there are more people having this
> > problem. Maybe, if more people are asking, then it will be recognized
> > as a problem?
> > Sorry for no better answer,
> > Markus
> > PS: Please note that there is the precompiled version
> > http://wingrass.fsv.cvut.cz/grass70/osgeo4w/
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111124/17bb221a/attachment.html
