[GRASS-user] getting error msg "g.echo.exe not found" to compile source code
Johannes Radinger JRadinger at gmx.at
Thu Nov 24 08:12:57 EST 2011
in Windows 7 there is the possibility to merge to folders with
the same name. So the folder have to be merged and already existing
files (not folders) should be replaced by the newer one.
Same for point 6 in the wiki.
/Johannes
-------- Original-Nachricht --------
> Datum: Thu, 24 Nov 2011 18:31:21 +0530
> Von: Sandip Maity <sandip.stesalit at gmail.com>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] getting error msg "g.echo.exe not found" to compile	source code
> Dear Johannes,
> "Unzip the folder and copy its sub folder contents into the corresponding
> sub folders of c:\osgeo4w\apps\msys."=> I have to copied every sub folder
> of the make file to msys directory. in many cases the sub folder name also
> same. then i have to digging or overwrite.
> In compile_on_windows, please see the 6th step here also i am facing same
> problem for copying.
> Please help me.
> Thanks and regards.
> Sandip
> On Thu, Nov 24, 2011 at 3:03 PM, Johannes Radinger <JRadinger at gmx.at>
> wrote:
> > Hello,
> > How did you install the new make 3.81?
> > as I had the same problem some weeks ago,
> > here what needs to be done (at least in my case):
> > 1) It is really important to follow the wiki (compile_on_windows)!
> > 2) Download the latest make program compliant with the OSGeo4W framework
> > from  here. (download only from here and not any installer or
> > anything...)
> > 3) Unzip the folder and copy its subfolder contents into the
> corresponding
> > subfolders of c:\osgeo4w\apps\msys. This step is really important!
> > 4) Close and re-open msys
> > 5) make -version
> > /Johannes
> > > Datum: Thu, 24 Nov 2011 09:01:01 +0100
> > > Von: Markus Neteler <neteler at osgeo.org>
> > > An: Sandip Maity <sandip.stesalit at gmail.com>
> > > CC: GRASS user list <grass-user at lists.osgeo.org>
> > compile source code
> > > On Thu, Nov 24, 2011 at 6:43 AM, Sandip Maity
> > > wrote:
> > > > I downloaded make 3.81.
> > > > But after installation make is 3.79.1
> > > > Please suggest any idea.
> > > Please contact the OSGeo4W list - there are more people having this
> > > problem. Maybe, if more people are asking, then it will be recognized
> > > as a problem?
> > > Sorry for no better answer,
> > > Markus
> > > PS: Please note that there is the precompiled version
> > > http://wingrass.fsv.cvut.cz/grass70/osgeo4w/
> > > _______________________________________________
> > > grass-user mailing list
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
> > Jetzt informieren: http://www.gmx.net/de/go/freephone
