can't find gui_modules/menuform.py -- was [GRASS-user] LiDAR LAS
import
Daniel Victoria
daniel.victoria at gmail.com
Fri Nov 25 10:56:51 EST 2011
Changed the subject so it's separated from the LIDAR discussion.
Markus N.: the latest svn has fixed the location wizard problem. It now works.
I'm still getting errors when I try to run v.in.lidar. It complains that:
python: can't open file
'/home/daniel/grass_src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py':
[Errno 2] No such file or directory
Is there anything I can do?
Cheers
Daniel
On Fri, Nov 25, 2011 at 1:00 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Nov 25, 2011 at 1:05 PM, Daniel Victoria
> <daniel.victoria at gmail.com> wrote:
>> Grass compilation went fine but unfortunatelly I still can't test it
>> because I'm having some other problems. Location Wizard is not opening
> I have fixed this in SVN, the files weren't installed after the layout
> change (r49356).
> Markus
