can't find gui_modules/menuform.py -- was [GRASS-user] LiDAR LAS
import
Markus Metz
markus.metz.giswork at googlemail.com
Fri Nov 25 11:16:20 EST 2011
Daniel Victoria wrote:
> Changed the subject so it's separated from the LIDAR discussion.
> Markus N.: the latest svn has fixed the location wizard problem. It now works.
> I'm still getting errors when I try to run v.in.lidar. It complains that:
> python: can't open file
> '/home/daniel/grass_src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py':
> [Errno 2] No such file or directory
> Is there anything I can do?
Not really. The wxGUI in trunk is currently largely broken due to
reorganization, will hopefully be fixed soon...
Markus M
> Cheers
> Daniel
> On Fri, Nov 25, 2011 at 1:00 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Nov 25, 2011 at 1:05 PM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>>> Grass compilation went fine but unfortunatelly I still can't test it
>>> because I'm having some other problems. Location Wizard is not opening
>> I have fixed this in SVN, the files weren't installed after the layout
>> change (r49356).
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
