[GRASS-user] 6.5svn Build Errors
Rich Shepard
rshepard at appl-ecosys.com
Mon Nov 28 15:01:44 EST 2011
I've been running 6.5svn but haven't used it for several months so I
decided to run 'svn up' and get the latest version (build 42410? from this
Monday morning). After running 'make clean' and re-configuring I'm getting
build errors for the first time.
These errors all appear to be html docs:
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
d.ask
d.barscale
d.colorlist
d.colors
d.colortable
d.correlate
d.erase
d.extend
d.extract
d.font
d.frame
d.geodesic
d.graph
d.grid
d.his
d.histogram
d.info
d.labels
d.legend
d.linegraph
d.m
d.mapgraph
d.measure
d.menu
d.mon
d.monsize
d.mvmon
d.nviz
d.out.file
d.out.gpsdrive
d.path
d.polar
d.profile
d.rast.arrow
d.rast.edit
d.rast
d.rast.leg
d.rast.num
d.redraw
d.resize
d.rgb
d.rhumbline
d.save
d.shadedmap
d.slide.show
d.split.frame
d.split
d.text
d.thematic.area
d.title
d.vect.chart
d.vect
d.vect.thematic
d.what.rast
d.what.vect
d.where
d.zoom
db.columns
db.connect
db.copy
db.describe
db.drivers
db.dropcol
db.droptable
db.execute
db.in.ogr
db.login
db.out.ogr
db.select
db.tables
db.test
g.access
g.ask
g.copy
g.dirseps
g.extension
g.filename
g.findetc
g.findfile
g.gisenv
g.gui
g.list
g.manual
g.mapset
g.mapsets
g.message
g.mkfontcap
g.mlist
g.mremove
g.pnmcomp
g.proj
g.region
g.remove
g.rename
g.setproj
g.tempfile
g.transform
g.version
i.atcorr
i.cca
i.class
i.cluster
i.fft
i.fusion.brovey
i.gensig
i.gensigset
i.group
i.his.rgb
i.ifft
i.image.mosaic
i.in.spotvgt
i.landsat.acca
i.landsat.rgb
i.landsat.toar
i.maxlik
i.modis.qc
i.oif
i.ortho.photo
i.pca
i.photo.2image
i.photo.2target
i.photo.camera
i.photo.init
i.photo.rectify
i.points
i.rectify
i.rgb.his
i.smap
i.spectral
i.target
i.tasscap
i.topo.corr
i.vpoints
i.zc
m.cogo
m.nviz.image
m.proj
ps.map
r.average
r.basins.fill
r.bilinear
r.bitpattern
r.blend
r.buffer
r.carve
r.category
r.circle
r.clump
r.coin
r.colors
r.colors.out
r.colors.stddev
r.composite
r.compress
r.contour
r.cost
r.covar
r.cross
r.describe
r.digit
r.distance
r.drain
r.external
r.fill.dir
r.fillnulls
r.flow
r.grow.distance
r.grow
r.gwflow
r.his
r.horizon
r.in.arc
r.in.ascii
r.in.aster
r.in.bin
r.in.gdal
r.in.gridatb
r.in.mat
r.in.poly
r.in.srtm
r.in.wms
r.in.xyz
r.info
r.kappa
r.lake
r.le.patch
r.le.pixel
r.le.setup
r.le.trace
r.li.cwed
r.li.dominance
r.li.edgedensity
r.li.mpa
r.li.mps
r.li.padcv
r.li.padrange
r.li.padsd
r.li.patchdensity
r.li.patchnum
r.li.pielou
r.li.renyi
r.li.richness
r.li.setup
r.li.shannon
r.li.shape
r.li.simpson
r.los
r.mapcalculator
r.mask
r.median
r.mfilter.fp
r.mfilter
r.mode
r.neighbors
r.null
r.out.arc
r.out.ascii
r.out.bin
r.out.gdal
r.out.gdal.sh
r.out.gridatb
r.out.mat
r.out.mpeg
r.out.pov
r.out.ppm
r.out.ppm3
r.out.tiff
r.out.vrml
r.out.vtk
r.out.xyz
r.param.scale
r.patch
r.plane
r.profile
r.proj
r.quant
r.quantile
r.random.cells
r.random
r.random.surface
r.reclass.area
r.reclass
r.recode
r.region
r.regression.line
r.report
r.resamp.interp
r.resamp.rst
r.resamp.stats
r.resample
r.rescale.eq
r.rescale
r.ros
r.series
r.shaded.relief
r.sim.sediment
r.sim.water
r.slope.aspect
r.spread
r.spreadpath
r.statistics
r.stats
r.sum
r.sun
r.sunmask
r.support
r.support.stats
r.surf.area
r.surf.contour
r.surf.fractal
r.surf.gauss
r.surf.idw
r.surf.idw2
r.surf.random
r.terraflow
r.texture
r.thin
r.tileset
r.timestamp
r.to.rast3
r.to.rast3elev
r.to.vect
r.topidx
r.topmodel
r.transect
r.univar
r.univar.sh
r.volume
r.walk
r.water.outlet
r.watershed
r.what.color
r.what
r3.cross.rast
r3.gwflow
r3.in.ascii
r3.in.v5d
r3.info
r3.mapcalculator
r3.mask
r3.mkdspf
r3.null
r3.out.ascii
r3.out.v5d
r3.out.vtk
r3.stats
r3.timestamp
r3.to.rast
r3.univar
v.buffer
v.build.all
v.build
v.build.polylines
v.category
v.centroids
v.class
v.clean
v.colors
v.convert.all
v.convert
v.db.addcol
v.db.addtable
v.db.connect
v.db.dropcol
v.db.droptable
v.db.join
v.db.reconnect.all
v.db.renamecol
v.db.select
v.db.univar
v.db.update
v.delaunay
v.digit
v.dissolve
v.distance
v.drape
v.edit
v.external
v.extract
v.extrude
v.generalize
v.hull
v.in.ascii
v.in.db
v.in.dxf
v.in.e00
v.in.garmin
v.in.geonames
v.in.gns
v.in.gpsbabel
v.in.lines
v.in.mapgen
v.in.ogr
v.in.region
v.in.sites.all
v.in.sites
v.in.wfs
v.info
v.kcv
v.kernel
v.krige.py
v.label
v.label.sa
v.lidar.correction
v.lidar.edgedetection
v.lidar.growing
v.lrs.create
v.lrs.label
v.lrs.segment
v.lrs.where
v.mkgrid
v.neighbors
v.net.alloc
v.net.allpairs
v.net.bridge
v.net.centrality
v.net.components
v.net.connectivity
v.net.distance
v.net.flow
v.net
v.net.iso
v.net.path
v.net.salesman
v.net.spanningtree
v.net.steiner
v.net.timetable
v.net.visibility
v.normal
v.out.ascii
v.out.dxf
v.out.gpsbabel
v.out.ogr
v.out.pov
v.out.svg
v.out.vtk
v.outlier
v.overlay
v.parallel
v.parallel2
v.patch
v.perturb
v.proj
v.qcount
v.random
v.rast.stats
v.reclass
v.report
v.sample
v.segment
v.select
v.split
v.support
v.surf.bspline
v.surf.idw
v.surf.rst
v.to.3d
v.to.db
v.to.points
v.to.rast
v.to.rast3
v.transform
v.type
v.univar
v.univar.sh
v.vol.rst
v.voronoi
v.what
v.what.rast
v.what.vect
And this is followed by:
GRASS GIS compilation log
Started compilation: Mon Nov 28 11:48:24 PST 2011
Errors in:
/home/rshepard/GIS/GRASS/grass-6.5svn/general/g.parser
/home/rshepard/GIS/GRASS/grass-6.5svn/imagery/i.ask
/home/rshepard/GIS/GRASS/grass-6.5svn/imagery/i.find
/home/rshepard/GIS/GRASS/grass-6.5svn/imagery/i.ortho.photo/i.photo.elev
/home/rshepard/GIS/GRASS/grass-6.5svn/imagery/i.ortho.photo/i.photo.target
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.support/modcats
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.support/modcolr
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.support/modhist
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.support/modhead
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.watershed/ram
/home/rshepard/GIS/GRASS/grass-6.5svn/raster/r.watershed/seg
When I change to ../g.parser and run 'make' I see errors related to the
html docs:
Can't open
'/home/rshepard/GIS/GRASS/grass-6.5svn/dist.i686-pc-linux-gnu/docs/html/g.parser.html'
for reading: No such file or directory at ../../tools/g.html2man/g.html2man
line 271.
It's the same for i.ask, i.find, and I assume the rest.
Suggestions? I need to use GRASS on a new project and would like a working
6.5 as quickly as possible.
Rich
