[GRASS-user] confused on categories created by topological cleaning
of overlapping polygons
G. Allegri
giohappy at gmail.com
Tue Nov 29 16:00:34 EST 2011
I'm still assessing the topological model and the build/clean effects on
various combinations of synthetic geometries created by myself.
This time I have created two overlapping polygons [1] [2] in Qgis, and
imported in grass thorugh v.in.ogr.
If I import the shapefile with the clean tool activated, I obtain 3 areas:
two with one category and one layer, the other one (the overlapping zone)
has two layers [3]:
layer 1: category 1/2
layer 2: category 1
BUT, the two layers appear only if I display the categories with v.digit.
All the other tools list only one layer (the one in common with the other
two areas).
This leads to various problems:
- the wxGUI (the identify tool inside the display window crashes)
- to remove the layer 2, because layer 2 isn't selectable from the other
modules (like v.category, etc.)
- to remove the second category from layer 1 I still have to use v.digit
because neither v.edit nor v.category let me choose the category number I
want to mantain/remove.
Is this the expected behaviour of overlapping regions cleaning?
giovanni
[1] image: http://www.giovanniallegri.it/share/test_polygon.png
[2] shapefile: http://www.giovanniallegri.it/share/test_polygon.zip
[3] http://www.giovanniallegri.it/share/cleaned_test_polygon.png
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111129/0f7ffbc3/attachment.html
