[GRASS-user] confused on categories created by topological
cleaning of overlapping polygons
Markus Metz
markus.metz.giswork at googlemail.com
Wed Nov 30 03:11:07 EST 2011
G. Allegri wrote:
> I'm still assessing the topological model and the build/clean effects on
> various combinations of synthetic geometries created by myself.
> This time I have created two overlapping polygons [1] [2] in Qgis, and
> imported in grass thorugh v.in.ogr.
> If I import the shapefile with the clean tool activated, I obtain 3 areas:
> two with one category and one layer, the other one (the overlapping zone)
> has two layers [3]:
> layer 1: category 1/2
> layer 2: category 1
> BUT, the two layers appear only if I display the categories with v.digit.
You can display all layers with d.vect layer=-1 or any specific layer
with d.vect layer=2. This is also possible in the wxGUI
> All the other tools list only one layer (the one in common with the other
> two areas).
This is not the tools, it's the wxGUI. The wxGUI only knows about
layers that have an attribute table attached to it. But wherever there
is a layer option, you can enter any number in the wxGUI, also numbers
not in the dropdown list
> This leads to various problems:
> - the wxGUI (the identify tool inside the display window crashes)
This is a recently introduced bug because the wxGUI is no longer using
v.what and needs an attribute table (which is a completely optional
feature for grass vectors).
> - to remove the layer 2, because layer 2 isn't selectable from the other
> modules (like v.category, etc.)
See above, of course layer 2 is selectable, just enter the number 2.
Or use CLI ;)
> - to remove the second category from layer 1 I still have to use v.digit
> because neither v.edit nor v.category let me choose the category number I
> want to mantain/remove.
v.category layer=2 option=del cat=-1 should successfully remove all
categories from layer 2.
> Is this the expected behaviour of overlapping regions cleaning?
If you mean that overlapping parts get an additional category in a new
layer, yes.
Markus M
> giovanni
> [1] image: http://www.giovanniallegri.it/share/test_polygon.png
> [2] shapefile: http://www.giovanniallegri.it/share/test_polygon.zip
> [3] http://www.giovanniallegri.it/share/cleaned_test_polygon.png
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
