[GRASS-user] AddOn or Script when compiling GRASS from source
William Kyngesburye
woklist at kyngchaos.com
Thu Oct 13 09:43:51 EDT 2011
Right, forgot about that.
On Oct 13, 2011, at 3:30 AM, Glynn Clements wrote:
> William Kyngesburye wrote:
>> I think the only reason GRASS keeps them separate is because Windows
>> needs them that way, and on Linux and OS X scripts can be in the
>> compiled "bin" folder without a problem. And at least on OS X it's best
>> that scripts be in the bin/ folder because it won't look in the addon
>> scripts folder to run them (I could fix that, but there are other issues
>> with multiple paths in GRASS_ADDON_PATH).
> There shouldn't be any need for that. Current usage of
> GRASS_ADDON_PATH in 7.0 is:
> lib/init/grass.py:
> path_prepend(addon_path, 'PATH')
> path_prepend(os.path.join(addon_path, 'scripts'), 'PATH')
> path_prepend(os.path.join(addon_path, 'bin'), 'PATH')
> gui/wxpython/gui_modules/globalvar.py:
> path = os.getenv('GRASS_ADDON_PATH')
> bpath = os.path.join(path, 'bin')
> spath = os.path.join(path, 'scripts')
> scripts/g.manual/g.manual.py:
> path = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', entry + '.html')
> path = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'man', 'man1', entry + '.1')
> IOW, GRASS_ADDON_PATH is supposed to be the root of the add-on
> hierarchy, analogous to GISBASE for the main installation.
> BTW, this (in lib/init/grass.py) is wrong:
> Its presence might indicate a bug somewhere else.
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
