[GRASS-user] AddOn or Script when compiling GRASS from source
Martin Landa
landa.martin at gmail.com
Thu Oct 13 10:56:45 EDT 2011
2011/10/13 Hamish <hamish_b at yahoo.com>:
> the fact that it has been used like that in trunk
> is a mistake I hope to remedy.
it's not a mistake.
> mainly by having trunk look for GRASS_ADDON_BASE
> instead of GRASS_ADDON_PATH if it is actually
> wanting --prefix= instead of $PATH.
OK, GRASS_ADDON_BASE could be a reasonable solution.
> [in grass6] GRASS_ADDON_PATH is what gets prepended
> to the OS's $PATH to look for executables. currently
> g.extension creates symlinks to ameliorate the
> misuse. FYI I plan to modify g.extension in grass6
> to install executables to the main ADDON dir,
> instead of to scripts/ and bin/ + symlinks back to
> the main dir. The current way is needlessly
> complicated.
In grass7 the extensions are installed to `.grass7/addons` (on Linux),
defining GRASS_ADDON_BASE would avoid bunch of GRASS_ADDON_*
variables. The `addons` directory has defined structure,
bin docs etc man scripts
In the result, only one variable GRASS_ADDON_BASE would be enough, to
define PATH (bin & scripts) ETC (etc) or MAN (man). Your suggestion is
to replace GRASS_ADDON_PATH (as used currently in trunk) by
GRASS_ADDON_BASE, right? if yes, it make sense to me.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
