[GRASS-user] v.vect.stats has no results
Markus Metz
markus.metz.giswork at googlemail.com
Tue Oct 18 07:35:28 EDT 2011
Andres Kuusk wrote:
>> and v.vect.stats after g.gisenv set="DEBUG=2".
> (Tue Oct 18 12:36:48 2011)
> g.gisenv set=DEBUG=2
> (Tue Oct 18 12:36:48 2011) Command finished (0 sec)
> (Tue Oct 18 12:36:58 2011)
> v.vect.stats -p points=tmp4 areas=rami type=point method=average
> pcolumn=uav8 ccolumn=nuav scolumn=uav8min --verbose
> (Tue Oct 18 12:36:58 2011) Command finished (0 sec)
Weird. With DEBUG=2, all sorts of debug messages should be printed.
Looks like the module exits immediately and can not even open the
vectors. Can you run it again through CLI, not the GUI (also not the
GUI-CLI)?
BTW, works fine for me with the North Carolina dataset.
Markus M
>> I am using GRASS-7, r47868.
> Andres
