[GRASS-user] v.vect.stats has no results
Andres Kuusk
andres at aai.ee
Tue Oct 18 15:36:02 EDT 2011
I am sorry, the module v.vect.stats was missing in my set-up. I tried to
start it through GUI-CLI, that was the output.
Now I upgraded GRASS-7 to r48840 or r48841 (I guess, sorry, I cannot
check, the Internet connection of office is down), and v.vect.stats works
fine. Thanks for your support.
However, the current version has again problems with using selection
options for a vector - the display window is empty if I turn on a
selection option. Vector(s) is(are) visible again if I turn the selection
option off. I will give more details when I can access Internet in my
office.
Andres
Tue, 18 Oct 2011, Markus Metz:
> Weird. With DEBUG=2, all sorts of debug messages should be printed.
> Looks like the module exits immediately and can not even open the
> vectors. Can you run it again through CLI, not the GUI (also not the
> GUI-CLI)?
