[GRASS-user] v.to.points
Marcello Gorini gorini at gmail.com
Tue Oct 18 08:20:34 EDT 2011
As far as I know, v.to.points does not write to an external file, it creates
a point vector map within GRASS.
So you should do output=pointmap and then use another module such as
v.out.ascii to generate an actual text file with the points.
Also, when you do that, do not enclose the output portion of the code with
quotes, you don't need them to set a path to the ouput file.
Hope it helps,
Marcello.
On Tue, Oct 18, 2011 at 9:59 AM, ALT SHN <i.geografica at alt-shn.org> wrote:
> Hello,
> I'm having problmes with module v.to.points.
> The input is a line shapefile with only two atributtes (both of them
> integers). I always get this error message:
> v.to.points input=AplanadoGRASS at InterpolationTEST type=line llayer=1
> "output=C:/Users/Andre
> Mano/Desktop/InterpolationBenchmark/Vectores_Pontos/pontosaplanado" dmax=20
> -v
> Nome de arquivo ilegal. O caractere n�o � permitido.
> Illegal vector map name . Character ':' not allowed.
> Output vector map name is not valid map name
> Finished with error
> I'm using GRASS 6.4 through QGIS 1.7 GRASS plugin in a Windows 7
> Professional environment
> Any hints would be very welcomed!!
> Associação Leonel Trindade
> SOCIEDADE DE HISTÓRIA NATURAL
> Apartado 25 2564-909 Torres Vedras Portugal
> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
> do Ameal 2565-641 Ramalhal
> http://alt-shn.blogspot.com
> www.alt-shn.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111018/9a92f944/attachment-0001.html
