[GRASS-user] v.to.points
ALT SHN
i.geografica at alt-shn.org
Tue Oct 18 09:06:29 EDT 2011
Thanks a lot!
(actually i'm feeling kinda dumb!! :) )
I assumed the output would be external to GRASS because of the browser
buttom [. . .]
Problem solved!
2011/10/18 Marcello Gorini <gorini at gmail.com>
> As far as I know, v.to.points does not write to an external file, it
> creates a point vector map within GRASS.
> So you should do output=pointmap and then use another module such as
> v.out.ascii to generate an actual text file with the points.
> Also, when you do that, do not enclose the output portion of the code with
> quotes, you don't need them to set a path to the ouput file.
> Hope it helps,
> Marcello.
> On Tue, Oct 18, 2011 at 9:59 AM, ALT SHN <i.geografica at alt-shn.org> wrote:
>> Hello,
>> I'm having problmes with module v.to.points.
>> The input is a line shapefile with only two atributtes (both of them
>> integers). I always get this error message:
>> v.to.points input=AplanadoGRASS at InterpolationTEST type=line llayer=1
>> "output=C:/Users/Andre
>> Mano/Desktop/InterpolationBenchmark/Vectores_Pontos/pontosaplanado" dmax=20
>> -v
>> Nome de arquivo ilegal. O caractere n�o � permitido.
>> Illegal vector map name . Character ':' not allowed.
>> Output vector map name is not valid map name
>> Finished with error
>> I'm using GRASS 6.4 through QGIS 1.7 GRASS plugin in a Windows 7
>> Professional environment
>> Any hints would be very welcomed!!
>> Associação Leonel Trindade
>> SOCIEDADE DE HISTÓRIA NATURAL
>> Apartado 25 2564-909 Torres Vedras Portugal
>> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres
>> Vedras
>> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
>> do Ameal 2565-641 Ramalhal
>> http://alt-shn.blogspot.com
>> www.alt-shn.org
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do
www.alt-shn.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111018/d7c9a9db/attachment.html
