[GRASS-user] Getting Gridded Population of the World (GPW) data
into GRASS
Markus Neteler
neteler at osgeo.org
Thu Oct 20 03:13:52 EDT 2011
On Thu, Oct 20, 2011 at 3:43 AM, Ben Madin
<lists at remoteinformation.com.au> wrote:
> G'day all,
> I have tried to search for this, but the only chain I found included some off-list component, and I'm not sure what actually happened.
> I have not been able to import GPW data into GRASS successfully.
I can confirm that, unfortunately.
> I am downloading data from http://sedac.ciesin.columbia.edu/gpw/global.jsp
> I have downloaded the .bil, the ascii grid and the ESRI GRID data types for population count and population density
> for example
>> r.in.gdal -o input=/Users/benmadin/Spatial/raster/gl_gpwfe_pcount_10_bil_25/glp10ag.bil output=glp10ag
> WARNING: Over-riding projection check
> 100%
> r.in.gdal complete. Raster map <glp10ag> created.
Now you first have to set the computational region to the map, otherwise
r.* will not compute reasonable results (unless you want to work on a
subregion).
But:
gdalinfo glp15ag
GEOGCS["WGS 84",
Upper Left (-180.0000000, 85.0000000) (180d 0'0.00"W, 85d 0'0.00"N)
Lower Left (-180.0000000, -58.0000000) (180d 0'0.00"W, 58d 0'0.00"S)
Upper Right ( 180.0000000, 85.0000000) (180d 0'0.00"E, 85d 0'0.00"N)
Lower Right ( 180.0000000, -58.0000000) (180d 0'0.00"E, 58d 0'0.00"S)
Center ( 0.0000000, 13.5000000) ( 0d 0'0.00"E, 13d30'0.00"N)
Band 1 Block=8640x1 Type=Float32, ColorInterp=Gray
this looks ok to me. However, neighter GRASS 6 nor 7 can import it
correctly, some epsilon issue:
# note that -l doesn't change anything:
r.in.gdal glp15ag out=population_2015 -l
r.info population_2015
| Rows: 3432 |
| Columns: 8640 |
| Total Cells: 29652480 |
| Projection: Latitude-Longitude |
| N: 85N S: 58S Res: 0:02:30 |
| E: 179:59:59.999999W W: 180W Res: 0 |
| Range of data: min = 0 max = 1870454 |
g.region rast=population_2015 -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: a=6378137 es=0.00669438
north: 85N
south: 58S
west: 180W
east: 179:59:59.999999W <<--- !!!
nsres: 0:02:30
ewres: 0
rows: 3432
cols: 8640
cells: 29652480
d.rast.leg population_2015
ERROR: region for current mapset is invalid
line 9: <e-w resol: 0>
run "g.region"
run "g.region"
We need to add something more in lib/gis/adj_cellhd.c in function
G_adjust_Cell_head().
Markus
