[GRASS-user] AddOn or Script when compiling GRASS from source
Hamish
hamish_b at yahoo.com
Sun Oct 23 13:45:18 EDT 2011
> Martin wrote:
> > so what's the preferred solution for G7
> > 1) single variable GRASS_ADDON_PATH for all components
> > (as it is)
> > 2) two variables - GRASS_ADDON_BASE and
> > GRASS_ADDON_PATH (path only as in G6)
Glynn:
> #1. Although the name doesn't matter.
> If the user wants to add extra executable directories,
> they can modify PATH directly.
[moving this thread over to the dev list]
as per earlier email in this thread, from my POV option
#2 is the preferred solution. Definitely change the name
away from PATH for usage which isn't $PATH anymore.
if it doesn't harm to automatically prepend the $PATH,
then why not make that easy for those who want to use it?
Hamish
