[GRASS-user] strange expresion in selected map name
Juan Miguel Garijo saldinet at yahoo.es
Mon Oct 24 01:41:28 EDT 2011
Hello,
Choosing a map layer with the browser of any module appears a expresion like this:
mapName at en mapasDatasetName
adding 'en mapas' at the normal one mapName at DatasetName
So, after it can't read it well and there is un error like 'map no exists'.
Erasing 'en mapas' in the expresion, everything go well.
Working with last GRASS 6.4.2RC1 of georepository of openSuse11.3 in spanish.
can be a traslation matter?
Tanks
J.M. Garijo
----- Mensaje original -----
De: Hamish <hamish_b at yahoo.com>
Para: Martin Landa <landa.martin at gmail.com>; Glynn Clements <glynn at gclements.plus.com>
CC: grass-user at lists.osgeo.org; grass-dev at lists.osgeo.org
Enviado: domingo 23 de octubre de 2011 19:45
Asunto: Re: [GRASS-user] AddOn or Script when compiling GRASS from source
> Martin wrote:
> > so what's the preferred solution for G7
> > 1) single variable GRASS_ADDON_PATH for all components
> >    (as it is)
> > 2) two variables - GRASS_ADDON_BASE and
> >    GRASS_ADDON_PATH (path only as in G6)
Glynn:
> #1. Although the name doesn't matter.
> If the user wants to add extra executable directories,
> they can modify PATH directly.
[moving this thread over to the dev list]
as per earlier email in this thread, from my POV option
#2 is the preferred solution. Definitely change the name
away from PATH for usage which isn't $PATH anymore.
if it doesn't harm to automatically prepend the $PATH,
then why not make that easy for those who want to use it?
Hamish
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111024/e1612760/attachment.html
