[GRASS-user] Re: Add DB entries to vector line (after v.split)
wittich
vwittich at gmail.com
Sun Oct 23 14:11:43 EDT 2011
Okay I found a solution, but its no very elegant. I exported the vector into
a shape and imported it then again:
> v.out.ogr -ce input=split_lines type=line dsn=./split_lines.shp
> format=ESRI_Shapefile
> v.in.ogr -o dsn=./split_lines.shp out=split_lines1
But there should be another way...
Thx
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Add-DB-entries-to-vector-line-after-v-split-tp6922423p6922499.html
Sent from the Grass - Users mailing list archive at Nabble.com.
