[GRASS-user] Re: GRASS 7 configuration with libLas
ahmadou dicko
dicko.ahmadou at gmail.com
Mon Oct 24 12:10:01 EDT 2011
Hi Markus
I installed liblAs from source (here) so I already have the header :
/usr/local/include/liblas/liblas.hpp
/usr/local/include/liblas/capi/liblas.h
Is not an issue and it works...i just want to share this because when i
faced this problem googling was not very helpful to me.
And if someone have the same problem it can be fix using this method
(symlink) for the time being.
Ahmadou
2011/10/24 Markus Metz <markus.metz.giswork at googlemail.com>
> ahmadou dicko wrote:
> > Hi everyone
> > Trying to compile GRASS 7 I had an issue similar to the one on this
> thread :
> > http://lists.osgeo.org/pipermail/grass-dev/2011-May/054559.html
> > I built the latest version of libLAs from repository (version 1.7) and
> it's
> > appear that on ubuntu the shared library have different name than those
> of
> > previous version of libLAs .
> > So my guess is that GRASS wait for liblas.so and liblas_c.so but in
> > /usr/local/lib there are only liblas.so.2.0 and liblas_c.so.2.0 (for
> newer
> > version of libLAs --someone can confirm ?)
> > So to fix this problem, I create some symlink like this
> > sudo ln -s liblas.so.2.0 liblas.so
> > sudo ln -s liblas_c.so.2.0 liblas_c.so
> > Hope this will help
> > There is another work around for this problem ?
> You also need to install the devel package of libLAS. This will
> provide liblas.so and liblas_c.so and the headers necessary to compile
> GRASS 7 with libLAS support.
> Markus M
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? enlev?e...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111024/cc6d1234/attachment.html
