[GRASS-user] Re: Add DB entries to vector line (after v.split)
wittich
vwittich at gmail.com
Tue Oct 25 15:37:36 EDT 2011
Alexander Muriy wrote:
> It looks strange. Can you give the output of commands <v.info> and
> <v.category in=vector opt=report> for your segments vector?
> v.info lines_split
| Layer: lines_split
| Map format: native
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 0
| Number of lines: 598 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: No
| Number of dblinks: 1
| Digitization threshold: 0
| Comments:
> v.category in=lines_split opt=report
Layer/table: 1/lines_split
type count min max
point 0 0 0
line 598 1 3
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 598 1 3
> Deletion of the table is unnecessary, because cats in table are
> depended on categories
> of the vector objects. So all work is around categories.
Thx for the explanation.
> > ps: I'm gonna try your shell-script (v.to.equidist), as soon I'll have
>> installed the GRASS-Addons. Right now it didn't find the grass/gis.h
>> while
>> he compiled it...
> I hope you're not going to compile a script? :)
Nope I try to install with the GRASS-Addons using <g.extension
extension=r.fuzzy.system>. But this command try to compile something...
whatever... and can't find grass/gis.h while it doing this, even if it
exist under /usr/lib/grass64/include/grass/gis.h. Maybe the compiling
process looks for the 32-lib. I didn't figure it out though.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Add-DB-entries-to-vector-line-after-v-split-tp6922423p6930154.html
Sent from the Grass - Users mailing list archive at Nabble.com.
