[GRASS-user] mapset not found: problem with file permissions?
Glynn Clements
glynn at gclements.plus.com
Thu Oct 27 23:39:13 EDT 2011
Damian M wrote:
> I am having a difficult time accessing a workspace that is located on mounted
> drive via fstab in Ubuntu as follows:
> //some.windows.share/share$ /media/remoteDir cifs
> iocharset=utf8,credentials=/.../.../.credentialsFile,file_mode=0775,dir_mode=0775,uid=userNumber,gid=groupNumber
> I can read/write to the directories outside of GRASS.
> When I start grass65svn and navigate the workspace on the server, I cannot
> open it, but when I check permissions with ls -l it says I have rwx
> permissions. I get an error message that says GRASS cannot find the mapsset
> I am trying to open.
> I can open the same mapset if it is on my local drive. Same permissions on
> the local directory with ls -l.
> Any help would be greatly appreciated.
If you want to select a mapset as the current mapset, you must be the
owner; write permission is insufficient.
This check is skipped for Windows versions of GRASS, but is performed
for Unix versions regardless of the filesystem type.
