[GRASS-user] mapset not found: problem with file permissions?
Damian M maddalena at nc.rr.com
Thu Oct 27 15:28:50 EDT 2011
I am having a difficult time accessing a workspace that is located on mounted
drive via fstab in Ubuntu as follows:
//some.windows.share/share$ /media/remoteDir cifs
iocharset=utf8,credentials=/.../.../.credentialsFile,file_mode=0775,dir_mode=0775,uid=userNumber,gid=groupNumber
I can read/write to the directories outside of GRASS.
When I start grass65svn and navigate the workspace on the server, I cannot
open it, but when I check permissions with ls -l it says I have rwx
permissions.  I get an error message that says GRASS cannot find the mapsset
I am trying to open.
I can open the same mapset if it is on my local drive.  Same permissions on
the local directory with ls -l.
Any help would be  greatly appreciated.
Thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/mapset-not-found-problem-with-file-permissions-tp6937759p6937759.html
Sent from the Grass - Users mailing list archive at Nabble.com.
