[GRASS-user] Re: r.in.gdal oddity
Helmut Kudrnovsky hellik at web.de
Sun Oct 30 19:27:37 EDT 2011
>I have read that and done that. I get the same information. Yes, in this
>case I am supposed to use the -l flag, but I get the same result (as I
>wrote).
>Now r.region lets me pull and stretch as I wish. Notice the slight
>difference in e-w resolution. Maybe that could be the key.
AFAIK there seems to be some precision issue (e-w resolution)
in the producing work flow of this data. I've opened the asc and the ESRI
grid also in
ArcGIS 10, there is this same little difference in the data extent.
>Nonetheless,
>it is odd that even with overriding the projection check AND OR forcing
>the map to fit within the bounds, the map is still a bit "skinny"...
you're right. maybe Markus M (cc'ed) has some more insight into this?
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-in-gdal-oddity-tp6944754p6946588.html
Sent from the Grass - Users mailing list archive at Nabble.com.
