[GRASS-user] v.in.ogr.qgis error has no details
Aren Cambre
aren at arencambre.com
Sun Sep 4 20:47:35 EDT 2011
I am running the GRASS 6.4.1 that is bundled with QGIS 1.7.
When I run v.in.ogr.qgis from the UI, I end up with an error. The source is
a QGIS PostGIS layer that is just geometry points.
>From the error details, I assume that v.in.ogr.qgis is just a bridge between
QGIS and v.in.ogr as the actual error message is from v.in.ogr.
The command doesn't work, and the error message is unhelpful. Here's the
module's output:
*v.in.ogr -o "dsn=PG:dbname='de' host=localhost port=5432 user='postgres'
password='[redacted]' sslmode=disable" "layer=raw.TxDOT crash"
"where="Cnty_ID" = '57'" output=pointdata snap=-1 min_area=0.0001*
*Over-riding projection check*
*Layer: raw.TxDOT crash*
*Default driver / database set to:*
*driver: dbf*
*database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/*
*Counting polygons for 264398 features...*
*Importing map 264398 features...*
*DBMI-DBF driver error:*
*Cannot insert new row: insert into pointdata values ( 1, '[redacted--was a
time]', '', 1, NULL, 32.959261, 2, NULL, NULL, NULL, 6, 0, NULL, 'N', '',
NULL, 0, NULL, NULL, NULL, NULL, '', NULL, 0, 2, '762', '', NULL, 0, NULL,
0, NULL, NULL, NULL, '', 'N', NULL, 0, NULL, 'E BETHEL SCHOOL RD', 8, NULL,
0, NULL, 4, 38, NULL, NULL, NULL, '', 'N', NULL, NULL, 'N', 1, NULL, 94, '',
NULL, NULL, 8, 22, 22, NULL, NULL, 'N', 'N', '[redacted--was a date]', NULL,
2, NULL, '', 'N', NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL,
NULL, NULL, 0, NULL, 0, 1, 0, 1, NULL, NULL, 5, 'Y', NULL, NULL, NULL, '',
3, '', NULL, '', 1, 2, NULL, 'N', 'MOCKINGBIRD LN', NULL, 1, '', 57, NULL,
1, NULL, NULL, 64, 0, 1, NULL, 0, NULL, NULL, NULL, '', 1, 0, NULL, 'N',
NULL, 'N', 0, NULL, 1, NULL, 2003000146, 'Y', '', NULL, 0, NULL, '', 2, 'Y',
-96.968529, 0, 0, NULL )*
*Finished with error*
I have no idea why this insert didn't work; the error has no details.
Searching online, it appears this error message almost always has an
explanation provided by GRASS.
Is there something that is being done to suppress the error details here?
Aren
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110904/014cd9b2/attachment.html
