[GRASS-user] Re: v.in.ogr.qgis error has no details
Aren Cambre
aren at arencambre.com
Sun Sep 4 23:19:02 EDT 2011
I reported this as a bug: http://trac.osgeo.org/grass/ticket/1439.
It also happens with the standalone copy of GRASS GIS 6.4.1.
Aren
On Sun, Sep 4, 2011 at 7:47 PM, Aren Cambre <aren at arencambre.com> wrote:
> I am running the GRASS 6.4.1 that is bundled with QGIS 1.7.
> When I run v.in.ogr.qgis from the UI, I end up with an error. The source is
> a QGIS PostGIS layer that is just geometry points.
> From the error details, I assume that v.in.ogr.qgis is just a bridge
> between QGIS and v.in.ogr as the actual error message is from v.in.ogr.
> The command doesn't work, and the error message is unhelpful. Here's the
> module's output:
> *v.in.ogr -o "dsn=PG:dbname='de' host=localhost port=5432 user='postgres'
> password='[redacted]' sslmode=disable" "layer=raw.TxDOT crash"
> "where="Cnty_ID" = '57'" output=pointdata snap=-1 min_area=0.0001*
> *Over-riding projection check*
> *Layer: raw.TxDOT crash*
> *Default driver / database set to:*
> *driver: dbf*
> *database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/*
> *Counting polygons for 264398 features...*
> *Importing map 264398 features...*
> *DBMI-DBF driver error:*
> *Cannot insert new row: insert into pointdata values ( 1, '[redacted--was
> a time]', '', 1, NULL, 32.959261, 2, NULL, NULL, NULL, 6, 0, NULL, 'N',
> '', NULL, 0, NULL, NULL, NULL, NULL, '', NULL, 0, 2, '762', '', NULL, 0,
> NULL, 0, NULL, NULL, NULL, '', 'N', NULL, 0, NULL, 'E BETHEL SCHOOL RD', 8,
> NULL, 0, NULL, 4, 38, NULL, NULL, NULL, '', 'N', NULL, NULL, 'N', 1, NULL,
> 94, '', NULL, NULL, 8, 22, 22, NULL, NULL, 'N', 'N', '[redacted--was a
> date]', NULL, 2, NULL, '', 'N', NULL, NULL, NULL, NULL, NULL, NULL, NULL,
> NULL, NULL, NULL, NULL, 0, NULL, 0, 1, 0, 1, NULL, NULL, 5, 'Y', NULL, NULL,
> NULL, '', 3, '', NULL, '', 1, 2, NULL, 'N', 'MOCKINGBIRD LN', NULL, 1, '',
> 57, NULL, 1, NULL, NULL, 64, 0, 1, NULL, 0, NULL, NULL, NULL, '', 1, 0,
> NULL, 'N', NULL, 'N', 0, NULL, 1, NULL, 2003000146, 'Y', '', NULL, 0, NULL,
> '', 2, 'Y', -96.968529, 0, 0, NULL )*
> *Finished with error*
> I have no idea why this insert didn't work; the error has no details.
> Searching online, it appears this error message almost always has an
> explanation provided by GRASS.
> Is there something that is being done to suppress the error details here?
> Aren
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110904/7d801c89/attachment.html
