[GRASS-user] import shpfiles dbmi: Protocol error
Markus Neteler neteler at osgeo.org
Thu Sep 8 03:55:36 EDT 2011
On Wed, Sep 7, 2011 at 11:48 PM, Matthew Mulbrandon <mulbran at hotmail.com> wrote:
> More info
> Ubuntu lucid
> grass 6.4.1
> The actual file can be downloaded at
> http://leegis.leegov.com/GISData.htm
> and the data set is called 'parcel and condo points' about 150 mb.
GRASS 6.4.2svn (florida):/tmp/dd > v.in.ogr
ParcelCondoAddressPoints20110831.shp
out=ParcelCondoAddressPoints20110831
Projection of input dataset and current location appear to match
Layer: ParcelCondoAddressPoints20110831
Counting polygons for 526067 features...
Importing map 526067 features...
 100%
Building topology for vector map <ParcelCondoAddressPoints20110831_tmp>...
Registering primitives...
526067 primitives registered
526067 vertices registered
Number of nodes: 451626
Number of primitives: 526067
Number of points: 526067
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: -
Number of isles: -
Building topology for vector map <ParcelCondoAddressPoints20110831>...
Building areas...
 100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
 100%
Number of lines: 0
Number of areas: 0
Number of isles: 0
For me it works fine in GRASS 6.4.svn. So, you may either update or wait for
the official 6.4.2 release hopefully in October.
Markus
