[GRASS-user] import shpfiles dbmi: Protocol error
    Matthew Mulbrandon
    mulbran at hotmail.com
    Wed Sep  7 17:48:46 EDT 2011
More info
Ubuntu lucid
grass 6.4.1
The actual file can be downloaded at
http://leegis.leegov.com/GISData.htm
and the data set is called 'parcel and condo points' about 150 mb.
Thanks,
Matthew
> Date: Wed, 7 Sep 2011 19:53:08 +0200
> Subject: Re: [GRASS-user] import shpfiles dbmi: Protocol error
> From: markus.metz.giswork at googlemail.com
> To: mulbran at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Wed, Sep 7, 2011 at 4:33 PM, Matthew Mulbrandon <mulbran at hotmail.com> wrote:
> > Hi,
> > Get nebulous error with data set from lee county. Bot dot data and parcel
> > data when importing.
> > v.in.org dsn="filepath" I don't want to write the whole thing.
> > "Projection of input dataset and current location appear to match.
> > output = dfds min_aria=0.0001 snap = -1
> > Layer: Lee-parcel
> > Counting polygons for 526085 features
> > Importing map 526085 features...
> > dbmi: Protocol error"
> > This happens about about 75 percent for the point map. 95 percent for the
> > parcel map.
> > I can open the dot file in qgis and the are 0 errors. I can clip and import
> > fine into grass.
> > So I think there might be a null value or maybe some other values that is
> > killing the import.
> > Any help would be appreciated.
> Can you please provide information about the GRASS version you use,
> the operating system and which database driver you are using (output
> of db.connect -p)?
> Thanks,
> Markus M
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110907/92000fba/attachment.html
