[GRASS-user] import shpfiles dbmi: Protocol error
Markus Metz
markus.metz.giswork at googlemail.com
Wed Sep 7 13:53:08 EDT 2011
On Wed, Sep 7, 2011 at 4:33 PM, Matthew Mulbrandon <mulbran at hotmail.com> wrote:
> Hi,
> Get nebulous error with data set from lee county. Bot dot data and parcel
> data when importing.
> v.in.org dsn="filepath" I don't want to write the whole thing.
> "Projection of input dataset and current location appear to match.
> output = dfds min_aria=0.0001 snap = -1
> Layer: Lee-parcel
> Counting polygons for 526085 features
> Importing map 526085 features...
> dbmi: Protocol error"
> This happens about about 75 percent for the point map. 95 percent for the
> parcel map.
> I can open the dot file in qgis and the are 0 errors. I can clip and import
> fine into grass.
> So I think there might be a null value or maybe some other values that is
> killing the import.
> Any help would be appreciated.
Can you please provide information about the GRASS version you use,
the operating system and which database driver you are using (output
of db.connect -p)?
Thanks,
Markus M
