[GRASS-user] Re: areas with islands and v.generalize
Georg Kaspar georg at muenster.de
Fri Sep 9 10:06:48 EDT 2011
Am 09.09.2011 15:44, schrieb Georg Kaspar:
> no difference. though i noticed that v.generalize does not get stuck a
> 62% when using the snakes algorithm - it just takes a long time to run.
> The result is nearly perfect though islands are still converted to
> polygons...
problem solved by running v.extrude -d on the results. Thank's Hamish, i
found the hint in another post of yours ;)
