[GRASS-user] areas with islands and v.generalize
Georg Kaspar
georg at muenster.de
Fri Sep 9 09:44:28 EDT 2011
Am 09.09.2011 15:04, schrieb Hamish:
> Georg wrote:
>> i'm trying to use v.generalize to smoothen polygon areas
>> generated by r.to.vect.
>> when using
>> v.generalize in=cold out=cold_smooth method=douglas
>> type=area thresh=0.1
>> the result remains the same as the input geometry.
> try running v.build.polylines first.
no difference. though i noticed that v.generalize does not get stuck a
62% when using the snakes algorithm - it just takes a long time to run.
The result is nearly perfect though islands are still converted to
polygons...
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110909/7b198415/signature.bin
