Georg wrote: > i'm trying to use v.generalize to smoothen polygon areas > generated by r.to.vect. > > when using > > v.generalize in=cold out=cold_smooth method=douglas > type=area thresh=0.1 > > the result remains the same as the input geometry. try running v.build.polylines first. Hamish
