[GRASS-user] areas with islands and v.generalize
Georg Kaspar
georg at muenster.de
Fri Sep 9 08:27:05 EDT 2011
Hi everyone,
i'm trying to use v.generalize to smoothen polygon areas generated by
r.to.vect.
when using
v.generalize in=cold out=cold_smooth method=douglas type=area thresh=0.1
the result remains the same as the input geometry.
Leaving out "type=area" leads to smoothened results though islands
become polygons.
v.generalize in=cold out=cold_smooth method=snakes
stops at 62%...
any ideas how to solve this problem?
thanks & best regards,
Georg
