[GRASS-user] Detecting GRASS version when only specifying GRASS directory
Rainer M Krug r.m.krug at gmail.com
Tue Sep 13 03:03:48 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Hamish, Ahmadou,
Hamish: The file VERSIONNUMBER is exactly what I was looking for - thanks.
Ahmadou:
On 13/09/11 02:12, ahmadou dicko wrote:
> The way Rainer use R for scripting GRASS don't allow  him to use
> the GRASS_VERSION variable, so i think the only way is to use the
> second solution proposed by Hamish.
Exactly.
> something like that should do the trick in R
> readLines(paste(Sys.getenv("GISBASE"), "etc", "VERSIONNUMBER", sep
Perfect.
> But if you launch R from GRASS or set some GRASS variable
> permanently you can simply do
> Sys.getenv("GRASS_VERSION")
Terue - but as you pointed out, I am not running R from within GRASS,
so the file VERSIONNUMBER is the way to go.
Thanks a lot,
Rainer
> 2011/9/12 Hamish <hamish_b at yahoo.com <mailto:hamish_b at yahoo.com>>
> Rainer wrote:
>> I am using GRASS from within an R script, and would need the
>> GRASS version. I do not know the startup script, so grass
>> --version is not an option. Nevertheless, I have obviously
>> specified the GRASS directory where the grass executables and
>> scripts sit. Is there one which I can use to get the grass
>> version?
> If grass is started you can use the GRASS_VERSION enviro variable
> or the g.version module to get it.
> If GRASS is not started you can look in the
> $GISBASE/etc/VERSIONNUMER file.
> Hamish
> _______________________________________________ grass-user mailing
> list grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk5vAFQACgkQoYgNqgF2egpSnwCfUZrg930ykKYaV97DCQV5hSx8
+SEAoIReUpAZOJ3B5M1WS7t3NoZ8xYga
=7s38
-----END PGP SIGNATURE-----
