Hi, I downloaded srtm elevation map (lat long) for Campania Region (Italy), now I want to reproject the map into another location (wgs84 33N). I try with the following command r.proj input=DTM_srtm location=latlong mapset=usr1 method=cubic but as results I have different z values. How can I fix this problem? Thanks. Salvatore
